Installed a G34 today
  • January 28, 2026
  • 58 views
internet speeds are slow, under 100mbps, when i was using the spectrum modem and router, averaged over 300…what might I be doing wrong?
Could you please confirm the speed plan you are currently subscribed to?
  • January 28, 2026
Testing over 2.4ghz?
5ghz?
Wired?
How are you testing? What device? What band?
Those are all key as 2.4ghz is a slow network and 100mbps is about right. Not for wired or 5ghz
  • January 30, 2026
I'm also having the same problem on my G34... Spectrum comes out and says my speed is 900 but I'm only getting 250 and 34 upload they say it's the modem router so I don't know I can't go back and forth with this
My phone my laptop my television and A friend brought their laptop to check the speed on there apple and it's all the same
any suggestions???
Are the speed drops happening only over Wi-Fi as well?
If the issue occurs on both Wi-Fi and wired connections, we recommend checking the cable signal levels within the gateway. If the signal levels are out of the acceptable range, they can lead to the kind of connectivity issues you're experiencing.
https://arris.my.salesforce-sites.com/consumers/articles/knowledge/G34-G36-Cable-Signal-Levels
The cable signal levels displayed on the interface page reflect the signals being transmitted by your Internet Service Provider (ISP).
If you notice that these signal levels are outside the recommended range, we suggest contacting your ISP to have them reviewed and adjusted accordingly.
While ISPs may have their own approved signal ranges, for this gateway to function properly, the signal levels must align with the acceptable values outlined in the reference article provided.
  • January 31, 2026
@Dfulton I’d encourage you to start your own post/thread so your details don’t get confused with the OP’s post and details.
