ip addresses
  • June 27, 2025
  • 24 views
Trying to identify unknown users on my g36 network. iMac is connected but address doesn’t match any of the four unknowns on the list
Make sure that you are connected to the primary home network. If you are connected to the guest or secondary network, it will not appear in the connected devices list.
If you are certain you are connected to the primary home network, make sure there is no VPN connected to your Mac, as VPNs can change the IP address on your device.
