iPad not connecting to G34 wifi
  • July 14, 2023
  • 381 views
Hi. This may be an obvious problem, but I can’t seem to figure it out.
I recently got the G34 and my iPad is not connecting to the wifi. I’ve reset the network settings on the ipad, tried 2.4 and 5 ghz networks, and the guest network.
I’ve also checked to see if the device is being blocked somehow, as well as added the MAC Address manually.
I know that the ipad wifi itself is working because it can connect to my phone’s hotspot.
I initially thought it was a software incompatibility, because the iOS version is 11.1 which is quite old. However since DOCSIS 3.1 is backwards compatible, I don’t think that would be the issue.
My old router was the Arris DG1670A, which I can confirm the ipad did work with.
Hi balenasandwich
As your iPad is not getting connected to WiFi lets change the Security mode for 24GHz and 5GHz :
Login to web manager page 192.168.0.1 : user name :admin and password: password (if not customized)
In gateway page select “Connection” go to “Networks” and to the right side you can see the gateway<connection<WiFi<edithome 2.4GHz
Select “Security Mode” by default it will be in “WPA2/WPA3 Mixed Personal (AES) (Recommended) to WPA2-PSK (AES),
Repeat the same for 5GHz
If still unable to connect iPad change the WiFi channels :Follow the below link
Hope this helps
Hi balenasandwich
Hope this helps
  • July 17, 2023
to WPA2-PSK (AES),
This worked, thanks!
