Ive recently switched my modem to the G34 Ive been trying to Mirror my Iphone using Reflector Software which worked on previous Modems ive used but for some reason now switching to this modem The reflector broadcast isnt available. are there some settings i need to change to make this work?
Iphone Mirroring not working with G34
Since the devices are not finding each other, I suggest you to change the security mode in Wi-Fi settings and try again.
To change the security mode, follow the steps given below:
>>Launch a browser and logon to 192.168.0.1.
>>Login the webpage with your credentials.
>>Once you logged in, select gateway>summary>connection>Wi-Fi>networks and edit.
>>Select security mode drop down and change it to either WPA2-PSK(AES) OR WPAWPA2-PSK(TKIP-AES).
Also check the firewall settings and make sure its selected as low.
