lan/ethernet on G34
  • February 17, 2024
  • 71 views
Why is my devices with lan cable the only devices lagging and when i go to the app it says that device has poor single can pls help.
what device is it?
What speeds is it getting?
You say its lagging, define that more. What speeds its getting, what is its tested latency/ping?
I’ve never seen a hardwired device say it has poor signal. It either works, or it doesn’t with hardwired devices. Are you sure you don’t still have it connected via wifi? Go into the settings on whatever device this is and re-run its network setup to ensure its using the hardwired connection
In this case we would suggest you to try using different ethernet cable like cat 5E or cat 6 and if still issue persist we need to check the cable signal level on the modem settings or GUI page.
  • February 20, 2024
what device is it?
