*LAN side* DHCP configuration?
  • July 27, 2025
  • 21 views
A few hours of searching and all I can find are people wanting me to look at my WAN-side DHCP.  I cannot emphasize enough that I’m asking about configuring the DHCP server functionality within the G36 that hands out IPv4 addresses to LAN client devices.  Nothing whatsoever to do with WAN side IP assignment.
Having tried to be excruciatingly clear, I want to know how to configure the IP address pool [and IP reservations] for the so-called ‘Secondary’ and ‘Guest’ subnets. Through the web GUI, I configured DHCP for the ‘Primary’ subnet to be 192.168.0.101 through 192.168.0.200, and now I want to know where in the web interface I would set the address pool for ‘Secondary’ to be 192.168.26.101 through 192.168.26.200, and similarly to set the ‘Guest’ address pool to be 192.168.28.101 through 192.168.28.200.  Presumably, if I find where to do this, I’ll also find the ability to declare IP reservations.
I read somewhere not to try logging into 192.168.26.1 or 192.168.28.1 with ‘password’ as it fouls up something else, but might that be how I find the DHCP server configuration for those subnets?
In the G36 gateway, only the primary network can be configured. It is not possible to set a custom IP address for the secondary or guest networks. Additionally, under the 'Connected Devices' section, you can only view devices that are connected to the primary network.
