Hello, I have tried 20 different ways to connect to the Modem/Router with my Win 10 Laptop and does not recognize it. It works on everything else except my work laptop. PLEASE HELP
Laptop does not recognized wifi on Arris G34
Instead of manually setting up a network on your computer, connect to your existing home network from the list of available networks. If you're unable to connect to the existing network, you may need to adjust the security mode on your Wi-Fi network. You can do this either through the Surfboard Central app (if you have it set up) or via the web access interface (GUI).
Please refer to the provided link for detailed steps on how to change the security mode on your Wi-Fi network.
http://arris.force.com/consumers/articles/knowledge/G34-G36-Unable-to-Connect-to-the-Wi-Fi-Network
After connecting to the network, verify that you can access websites. For your information, the G34 router operates on two bands: 2.4GHz and 5GHz. The 2.4GHz band offers greater coverage but lower speeds, while the 5GHz band provides higher speeds but less coverage. The actual speeds may vary depending on the client devices.
