Login issues G34
  • June 28, 2025
  • 85 views
I am still unable to login  to the web based interface,  even after Arris customer support guided me through  3 hard resets and 90 min. of wasted time.  Could this possibly have anything to do with the fact that I am not using the mobile app because I don’t have a smart phone.  I thought I could just use my desktop computer.  Can anybody help me; I only have 2 more days to return the thing to the store?
Before attempting to log into the web-based interface (GUI), make sure that your device is connected to the G34 network.
If the page loads and prompts you for a username and password, use 'admin' (all lowercase) for the username. For the password, use your customized one. When you first visit the GUI, it will ask you to create a login password. If you forget the password, perform a factory reset without the coaxial cable plugged in, as you mentioned you had tried resetting the gateway.
