Modem is not working and led light is amber on G34
  • June 3, 2024
  • 85 views
I would like to claim warranty on my Arris g34. Mines messed up and I did everything to fix it. The light is stuck on amber and I hit the reset button but it’s not doing anything.
If your modem is under warranty you can reach out to Arris.com/consumersupport for more assistance.
