MTU setting for G36
  • February 18, 2024
  • 218 views
Can the MTU setting be accessed and modified on Model G36?
If yes, where in the menu can the MTU setting be located?
Thank you.
Best answer by Larry G
Thank you.
No, G36 doesn't have MTU option on the modem settings or GUI.
  • February 21, 2024
Thank you.
