Need RMA/Refund for ARRIS G36 Surfboard
  • November 28, 2023
  • 118 views
I have had considerable issues with my ARRIS G36 Surfboard. The latest issue with the device dropping the 5GHz transmitter, is super frustrating and requires a reboot to resolve.  I submitted a topic on this (see attached) but no response from ARRIS (CommScope).  I wish this was my only issue, unfortunately, it’s not.
  • November 28, 2023
You have to go through support.
https://www.surfboard.com/support/resources/
We understand that you are unable to connect 5GHz as it keeps on disappearing only after rebooting the G36 it will stay connected again .
Lets try with possible options now :
  • In general if there is a firmware update  done recently  there are possibilities  for the 5GHz to get disappearing  hence check with your ISP if any firmware been update by them recently .
  • Lets try changing the Wi-Fi channels please follow the link below:
  • http://arris.force.com/consumers/articles/General_FAQs/G34-G36-Changing-the-Wi-Fi-Channel if still the 5GHz is disappearing.
  • Then select the Automatic Option on the above provided link and then select DCS Scan Interval and save the time Interval for 8 hours.
