New Arris Surfboard, Phones keep dropping Wifi, need to reboot a lot
  • March 8, 2023
  • 2261 views
We can’t stay connect to our Arris SURFboard Wi-Fi Cable Modem with our phones.  In addition when we do attempt to connect the various phone setting says that the password is wrong.  Reboot the cable modem and then after that we can connect.  Anyone have any ideas?
This is a new installation.
Hello  SealTeam7
                                If Wi-Fi drops or intermittent connection on Wi-Fi will be happening when If other Wi-Fi sources such as neighboring wireless access points are using the same wireless channel, this may cause intermittent connectivity issues, even if the competing signal is relatively weak. Changing the wireless channel within the  gateway can improve connectivity. Also make sure you have customized your default Wi-Fi credentials for security purpose and also that will help you in stay connected on all the devices. Please follow the steps mentioned on the link below to change the Wi-Fi channel. After changing Wi-Fi channel as recommended on the link restart the modem then we would request you to monitor the connection for next 24hrs.
Let us know if this helps
