Answer
New G34 drops connection every hour or so Spectrum
  • May 12, 2025
  • 94 views
Spectrum has me unplugging the G34 from power at least twice a day. They came out and said it’s the Arris issue?
Please make sure that your subscribed internet speed plan does not exceed 1 Gbps, as the G34 is only compatible with speeds up to 1 Gbps.
If the hardwired connection is working fine, the issue might be due to interference on the Wi-Fi frequencies.
To reduce interference and congestion, make sure the gateway is placed at a higher elevation and in an open space.
We also recommend changing the Wi-Fi channels if the gateway is in an open area. For instructions on how to change Wi-Fi channels, please refer to the link below.
http://arris.force.com/consumers/articles/knowledge/G34-G36-Changing-the-Wi-Fi-Channel
In the title, you mentioned that the G34 experiences connection drops. Does this issue occur with both Wi-Fi and hardwired connections?
Also, could you please let us know the speed plan you are subscribed to with your internet service provider?
  • May 25, 2025
I hardwired it and the issue is resolved. I can not forever only do this temporarily. Cords are hanging obverse doors. My computer is less than 30’ away. Spectrums fastest available
