Answer
no internet connection on 2.4g network on G34
  • June 26, 2024
  • 107 views
I
I purchased a I purchased an Aris surfboard G 34 router a week ago. But now, when I connect a device to the 5G Wi-Fi works fine. When I connect device to the 2.4 G Wi-Fi it does not get Internet.  I have an ethernet plugged in Verizon cell signal extender that worked up until this afternoon.
Now it does nothing
In this case could you please help us with the modem LED light status and have you tried restarting or resetting modem to check for the 2.4G wifi network?
Try logging to the modem GUI to disable and enable the 2.4G network and also need to check for the WAN IP address of the modem.
Launch a web browser, such as Internet Explorer, Firefox, or Safari.  Enter http://192.168.0.1 into the address box, and press the Enter key.  The https:// Redirect page will appear.
The Gateway > Connection > Wi-Fi > Networks page will appear.
Click on Edit for 2.4 network then click on enable
You can also try changing wifi name and password and
Save settings
Then try connecting devices to 2.4G network and check for the internet.
on the Status option on the left side menu you can check for the WAN IP address.
Save settings
