Renamed wifi now have 2 networks, unable to connect printer
  • March 23, 2025
  • 72 views
Cynthie
The Certified
I renamed my wifi, but now have 2 listed home networks ( the new name plus the original ).  My tv is connected to the newly named WiFi , but trying to set up printer and it keeps trying to connect to the original wifi name.  Should I delete the original, or are they both the same??
Surfboard AX3000
Infinity cable
  • March 24, 2025
What actual device do you have? AX3000 is a speed, not a model
did you change it through the app? Through the web browsers?
are you using a wireless extender?
Cynthie
The Certified
  • March 31, 2025
I have the Arris G36 cable modem/router (no extender).  I re-named the wifi through Comcast, but now have 2 separate wifi addresses (the other one prob when I set up the modem w/ Arris?)  I was finally able to connect my printer with the newly named wifi.
