Roku wireless red X with SurfBoard G36
  • January 10, 2024
  • 83 views
My Roku express+ and Surfboard G36 disconnect daily.  I have to do a system restart on the Roku to connect to the G36 and this is becoming troublesome.
I’m able to connect the Roku to the G36 successfully, however, randomly they stop communicating.  I asked Roku if it was the Roku device and they said no. because the Roku works correctly when I use my iPhone 15 hotspot.
Looking around some suggested I make sure the G36 is set up on “b/g/n” and it is in fact set up on “b/g/n/ax” for 2.4 GHz.
The issue has to be with the G36.  It’s new as of December 2023 and that when this issue started.
Any thoughts on a solution?
Best answer by allisonrja
I changed the 2.4 Ghz channel to 6 from the default channel of 11.  The problem, so far, has been resolved.  Thank you.
  • January 11, 2024
the Express+ is one of the most basic roku’s. Its not dual band.
Problem with that is 2.4ghz is sensitive to interference and its a slow network.
You can try changing the channel you’re using on the router to a less used channel. but if you live in a congested environment, a single band roku isn’t going to be your friend.
  • January 14, 2024
