setting up wireless devices
  • June 30, 2025
  • 75 views
I just installed a refurbished G 34 modem router combination. How do I set up a password to access the Internet on my wireless devices?
It is not necessary to set up a password for the G34, as it functions as both a modem and a router. By default, it provides a Wi-Fi name and password, which you can find in the available networks on your devices. Use the default password located at the bottom of the device.
