Single SSID issues
  • March 6, 2023
  • 797 views
I am unable to turn off Single SSID.  I enabled it at first thinking that it might help with a printer issue, but it didn’t, so I’m trying to turn it off to get the separate 2.4ghz and 5ghz SSIDs back.
I go into the SURFboard Central app on my Android phone, click the My Network tab, then the Network Management box.  I click the plus icon to open up the Main Wi-Fi Network box.  The slider for “Enable Single SSID for 2.4G/5G bands” is to the right and green.  I click on the slider to disable it, a box pops up warning me that it will disable the device band steering capability.  I click OK. A wheel spins on the screen for a second, then nothing.  Everything stays the same. I’ve tried this over and over and Single SSID will not turn off.
I have a G34 router.
Where the Wild Pings Are
Cable Modem Commandos
Forum|alt.badge.img+9
Hey Paperbag,
Have you tried making the change while connected to your mobile connection and not connected to the Wi-Fi of the G34? What may be happening is that when you make the change while connected to the G34 Wi-Fi your phone/tablet briefly drops the connection before the setting is saved.
If that’s not the case, you should be able to log into the GUI (interface) to make these changes. Since your using the app you would go to  “Access Web Interface” in the menu of the app, the username will be either the email address that you used to setup the app or admin and the app will give you the password, then tap the launch web GUI button. Once in the GUI you go to Connection > Wi-Fi > Networks. You should be able to make the changes from there.
Even when making the changes in the GUI, its a good idea to use a device that’s connected via ethernet or a device that is connected to a different network, it just helps to ensure that the connection doesn’t drop while trying to make the changes.
Hope that helps!
Hello Paperbag
                           In this case we would suggest you to perform restart on the modem for a minute when the app stuck on the loading screen and make sure that you stay next to the modem when you work on this steps. If still same issue persist you need to perform hard reset on the modem then re install app then after setting up you can try turn off the single SSID. But after resetting the modem will go to default setup any custom settings will be removed so use the default network name and password to connect to your network. If needed to perform hard reset in modem please follow the steps mentioned on link below
Let us know if this helps.
