Slow Download Speed on G34
  • July 20, 2025
  • 202 views
I have gigabit internet but my ethernet download speed is slow.  I have bypassed the splitter and have my Xfinity coax cable connected directly to my Arris G34 Gateway router. When I check over my wireless connection I get 350 Mbps. When I check over my ethernet I get about 200 Mbps.
The image you provided displays the cable signal levels received from the internet service provider through the gateway. Upon review, the signal levels appear to be within the acceptable operational range, indicating that there are no issues with the incoming signal quality at this time.
http://arris.force.com/consumers/articles/knowledge/G34-G36-Cable-Signal-Levels
We recommend performing a factory reset on your gateway. Please note that this will erase any previous custom configurations. However, rest assured—your internet connection will not be lost.
After the reset:
  1. Check your internet speeds to see if they have improved.
  2. Keep in mind that speed may vary depending on the device being used.
  3. Let us know the category of the Ethernet cable you're using (e.g., Cat5e, Cat6), as this can impact performance.
If the speeds are still below expectations, we suggest contacting your Internet Service Provider (ISP) to reprovision the gateway, which may help resolve the issue.
  • July 20, 2025
After the reset:
