slow speed internet connection on ethernet cable - G34
  • November 8, 2023
  • 158 views
How come when I try to change my Ethernet speed to 1000mbs it always revert back to 10mbs in the router setting?
If you are facing slow speed issue only on the direct connection we would suggest you to use different ethernet cable of cat6 or 7 and try checking speed on the device by connecting it to different ethernet port on the modem and if still same issue persist we would suggest you to check the cable signal level on the modem interface by following the steps mentioned on the below article. So here we will be checking the signal comes from out to inside the home. There are some important things that should be within a specific range in order for the internet to work properly.
First, the SNR should be above 33 on all of them. The downstream power should always be between -15 and +15. The closer to 0 the better connection. Finally, your upstream power should always be between +45 and +51
