I had sparklight as my provider for a year and the G34 worked perfectly. I recently moved states and had to change my provider to Xfinity and now I can't connect to internet. Since moving into the Apartment, the G34 when I plug it in goes green for 1 second then turns Amber color and stays like that. I have no access to wifi or internet through it. Has anyone encountered this problem?
Surboard G34 Constant Amber light
Best answer by Netopia
Make sure the G34 is compatible with the internet plan at the new location. I remember Xfinity couldn’t offer the same plan when I moved and had to change my plan that was compatible with my modem.
