How do I totally remove the 2nd home Wi-Fi and guest Wi-Fi from G34. Disabled all of these but Wi-Fi signal still transmitting.
Totally remove 2nd home wifi from G34
Yes, please unplug the power cord from the gateway and reconnect it after 10 seconds.
If the secondary home network signals are still broadcasting, disconnect the coaxial cable from the gateway and restart the device.
Once it powers back on—without the coaxial cable connected—log in to the web interface, restart the Wi-Fi module, and check again if the secondary network names are still being broadcast.
If they are, we recommend performing a factory reset of the gateway, again without the coaxial cable connected.
