Want Mesh System to work with G34
  • October 15, 2023
  • 581 views
What is the best mesh system to use with G34?
All the mesh system in Arris are best we have dual band and single unit router on mesh devices so you can choose accordingly. We would recommend W30 you can check the device details and specification on shop.surfboard.com
  • October 20, 2023
What size is your home?
What speeds do you pay for (and receive)?
What’s your budget?
What are you using it for? (gaming, streaming, etc)
  • October 24, 2023
The G34 is a cable modem + Wi-Fi router combo.  You can either put G34 in bridged mode to use as cable modem only and add Mesh System to provide Wi-Fi and network for your devices.  Or you can continue to use G34 as combo unit and add access points.
  • October 26, 2023
Thanks to all. I just purchased Arris W30 on Amazon.
