What is 'Registration' as a phase of establishing WAN activation/connection?
  • August 2, 2025
  • 55 views
What is WAN ‘registration’ in Arris G36 parlance when establishing a DOCSIS connection?
Using xFinity’s app, I had partial success activating a new G36 at a new service address.  In looking at the WAN status, I have QAM both up and down, and the various categories of activation all say ‘Complete’ except the final ‘Registration’ item which has displayed a couple different statuses depending on when I look.  The xFinity app’s progress always hangs and times out at ‘checking connections”.
Further, I wonder if this relates to me closing all the WAN side ports before I ever plugged the thing into xFinity.  Clearly xFinity won’t get no satisfaction if they are trying to ping the router from outside, but its fuzzy how that would result in the router itself never achieving ‘registration’.  TBH, I don’t even know what some of those other ports that default to open are used for, but I wanted to do what I could to prevent xFinity from forcing a firmware update that I cannot live with and cannot reverse. This G36 is very new and already running DOCSIS 3.1, but I don’t have the specific version at-hand as I craft this.
In poking around elsewhere in the forums, it might be relevant that I think I have IPv6 disabled on the WAN side, but I’m not in a position right now to enable it and retry the activation.
What does Arris G36 WAN ‘registration’ mean, and how might xFinity activation fail to provide what the router wants?  Any thoughts would be appreciated.
Best answer by RodHar00
Numerous web search result pages of AI and other slop about modem warranty registration later and I found my own answer.  The DOCSIS protocol culminates with processing to establish the actual IP connection from the modem to the ISP, probably including the DHCP handshake, and calls this phase ‘Registration’.  I’ll happily defer to anyone who wants to supply a more accurate or comprehensive answer.
In short, in my situation, the ‘Registration’ phase was not marked complete by the G36 because the prior phase of acquiring the configuration file, while marked complete was actually failing.  The event log showed the configuration file from xFinity being rejected as containing invalid TLV 4 content.  I’m going to open a separate thread on that.
  • August 4, 2025
