Just purchased a USED Arris G-36 and initial setup was fine. I had internet connection and WIFI going to all my smart devices. 2 days later, I have NO WIFI coming from the modem it seems? Logged into modem and used the (Spectrum Analyzer) and it shows NO other channels/Mac SSID etc. around me in the hood. I have ethernet connected to my desktop and this works fine. I have already done the following:
> Called Mediacom to ensure setup and that modem shows up on network.
(Logs from modem show initialization and also shows them re-initializing on day I called them 2 days later after losing radio signals on device.)
> Power reset
> Modem restart of WIFI
> Manual channel changes (still no connection to the smart devices)
> Used EVERY option in Restart/Restore while logged into the modem
Does this likely mean the WIFI radio software/hardware is no good? Should I return this as a defective modem? Or, is there something else anyone can suggest I try to get the wifi radio signals going?
