My modem keeps dropping WiFi every hour or so and I work from home all day, how do I fix this? Xfinity says its arris and needs update. I have to reboot non stop and causing work delays? Can you push the update! G34 MODEL , AX3000 WiFi 6.
Wi-Fi keeps dropping on G34
Since this happening on wifi i would suggest you to try changing wifi channels will avoid interference and that will give better speed and connection.
If other Wi-Fi sources such as neighboring wireless access points are using the same wireless channel, this may cause intermittent connectivity issues, even if the competing signal is relatively weak. Changing the wireless channel within the gateway can improve connectivity.
After changing wifi channel as recommended on the link restart the modem then we would request you to monitor the connection for next 24hrs.
