wifi usage
  • January 6, 2023
  • 63 views
How do you check the amount of wifi used monthly through the modem? I don’t want to check through the my provider. Also, is it possible to disconnect or pause devices on WiFi through the app or is an update coming for that?
  • January 6, 2023
You posted in the cable modem side.
What device do you actual have?  A modem alone won’t have that info.
  • January 6, 2023
Model g36
  • January 6, 2023
Maybe @SURFboard_Moderator would know. I don’t have that g36/34 models. Used to have a SBG8300 but no longer.
