G54 connecting with mesh system
  • October 6, 2024
  • 93 views
I have a G54 modem/router and I would like to make it a mesh system, what mesh system works best for that? I do need to be able to connect with an ethernet cable due to my pole barn having metal walls.
G54 is compatible with all mesh system so you can go with and you can check on W30, W121, SURFboard mAX® Express Kit are recommended also you can check on the product details and specification on shop.surfboard.com
