G54 in bridge mode
  • October 4, 2024
  • 60 views
When i put my G54 in bridge mode and connect it to tp-link Archer AX55 i have internet for about 5 mins and then I lose both wifi and land line connections.
Since your G54 device is on bridge mode it will be working as just the cable modem so regarding intermittent connection or internet drop out on Wi-Fi you need to check on the router only. If the same issue happening even when using G54 Wi-Fi then we can perform trouble shooting to check on the unit.
