how to split 2.4 and 5 g networks on the g54 arris
  • November 26, 2024
  • 1166 views
I’m having problems diving the networks 2.4 and 5 g I need to set up for cameras and I’m trying to do it in the app and I can’t find it anybody could help me
To enable the split mode, I would suggest following the instructions on the below-given link:
http://arris.force.com/consumers/articles/General_FAQs/G54-Multiple-SSIDs-Setup
  • November 26, 2024
On the g54, just log in through the browser and disable band steering. However, it ruins the point of the combining 2.4/5/6ghz for wifi 7. You should be able to set the cameras up without disabling band steering.
  • December 4, 2024
Thanks it works
they should clarify that with the manual
I am glad that it's working!
