MacBook Air not showing on Router's connected Devices
  • April 8, 2025
  • 6 replies
  • 130 views
padoughty
The Certified
Forum|alt.badge.img+3
Using MacBook Air (Mac) Sequoia 15.3 Chrome Browser.
I am able to connect to router and configure, but NEVER show up as a connected device.  iPhones, Printer (HP), SAMSUNG TV… But never my Mac… For that reason, I cannot connect to the printer.  Both iPhones do connect and print from the printer.
My Mac displays the Wi-Fi signal with full bars… I cannot ping any of the “connected” devices.  Firewall completely disabled (IPv4 & 6). (I don’t think I need a reboot) I CAN ping the router. I can reach the internet.  But not talking to anybody on my 192 Net. Rebooted twice… Change DHCP distributed IP…
I was able to ping addrs yesterday...
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
ether {Edit : personal information }
inet6 fe80::14da:e1da:829d:9dd7%en0 prefixlen 64 secured scopeid 0xb
inet 192.168.0.96 netmask 0xffffff00 broadcast 192.168.0.255
inet6 2601: 18c:8500:7b:54:6c84:2c17:1314 prefixlen 64 autoconf secured
inet6 2601: 18c:8500:7b:5c92:936:4d3:ac7c prefixlen 64 autoconf temporary
inet6 2601: 2601:18c:8500:7b:80f prefixlen 64 dynamic
nd6 options=201<PERFORMNUD,DAD>
media: autoselect
status: active
Make sure that your Mac is connected to the primary network, not the secondary or guest network. If your Mac is connected to either of those networks, it will not appear in the connected devices list.
  • April 8, 2025
the private mac/ip address and cloud relay/vpn can cause issues on macs. Have you disabled those on the mac?
Could you please help us with your product’s model number?
padoughty
The Certified
  • April 8, 2025
Model: G54
Disabled private mac address and private relay. Rebooted Mac… No identification as a connected device.  Noted my ip address changed as well as MAC address as I would expect…  No connection to printer (again)…. Had it last night following Mac update and reboot… Gone today…???
  • April 9, 2025
It was icloud relay you disabled?
padoughty
The Certified
  • April 11, 2025
Why? Why would my MAC not show up?
Previous Router - Time Capsule showed EVERY device connected… Including my MAC… And Windows laptop… Why not G54?
Also, the AP Isolation enabled resolved my printer issue… (By disabling it) A bit obscure… When enabled, prevents devices on the SAME  (192.168.0.1/24) network from communicating with each other wirelessly...
