Some of my devices won’t connect to the WiFi. It allows me to select the SSID and password but won’t connect. My old router had specific channels for 2.4 and 5G so it didn’t have a problem. Any suggestions?
some 2.4 Ghz devices won’t connect to G54
If you're having trouble connecting some devices to the Wi-Fi, I recommend changing the security mode.
To do this, log in to the web portal at 192.168.0.1.
Go to Gateway > Connection > Wi-Fi > Networks, then select Edit for the 2.4GHz network. After that, change the security mode to WPA/WPA2-PSK (TKIP/AES).
