wifi stopped working
  • June 27, 2025
  • 6 replies
  • 92 views
My Wi-Fi stopped working on multiple devices, some of my connected Wi-Fi is still working, ie, my TV, mobile phones, co.puters, but all of my other devices are offline, when connecting to the ssid it says no internet, yet other Wi-Fi connected devices are still connected. I can not connect my other devices as it says no internet on all broadcast ssids, I have factory reset the modem, yet still no success.
Are you able to receive an internet connection through a wired connection?
If yes, and if the issue is present on Wi-Fi connected devices, please make sure that the gateway is placed in an open area at a higher elevation to avoid interference.
If the issue persists with the Wi-Fi, we recommend changing the Wi-Fi channels to the least congested one.
For your reference, please refer to the link below on how to change the Wi-Fi channels.
http://arris.force.com/consumers/articles/knowledge/G54-Changing-the-Wi-Fi-Channel
  • June 27, 2025
What modem and router do you have?
  • June 27, 2025
Could you please let us know the name of your internet service provider and specify whether they provide a coaxial connection or a fiber optic connection? Additionally, please provide the LED light status on the gateway.
  • July 7, 2025
Xfinity, coaxial cable, the light is blue
  • July 10, 2025
The wired connection works, the same thing happened to my Xfinity supplied modem and they had to replace it with a new one. I tried to reset the modem but pressing the button for 30 seconds doesn't reset the modem. I guess I will have to buy a new one to replace it.
