connect with verizon hotspot
  • December 8, 2024
  • 64 views
Is it possible to connect an ac3800 max tri-band to a version hotspot that has an eternity port? Thanks in advance!
  • December 8, 2024
What device do you want to connect to a verizon hotspot? (model)
Most device could be connected to the hotspot, they just need to be setup correctly
  • December 8, 2024
Thanks so much for your reply! Inseego mifi x pro m3000. I'm not sure what I'm doing wrong. The led flashes green to red..... connected with an ethernet to the wan port.
  • December 9, 2024
What router do youo have? AC3800 is a speed.
MOre than likely you’re running into a double nat issue. thats where you cascade routers.
Usually you’d need to put the Inseego in passthrough mode or the AC3800 in access point mode to prevent the double nat.
  • December 9, 2024
WC4S?
  • December 9, 2024
not sure if the wc4s has a access point mode you could put it in when you connect it to the inseego
