Max W121 setup issues
  • October 8, 2023
  • 1513 views
Hello:
The setup app gets stuck with a couple different error codes when trying to install my new W121 mesh system.  First error code was 0006-1205.  Latest error code is 0001-1201.  The WiFi connection seems to be failing with my Android/Samsung phone.  I’m right next to the device and should have a good connection.  I’ve rebooted the W121 several times.  Switched to a second WAP and now get a different error code:  0000-1204.  The system does not seem to want to stay connected to my phone to be able to proceed through the setup.  Any advide would be appreciated.
Hello enlarson
                         In this case we would suggest you follow the below trouble shooting to complete the setup.
                        » Make sure you are getting internet from the modem where the router is connected
                        » Uninstall the Surfboard application
                        » Perform hard reset on the main router for 15-30 secs
                        » After the router reboots install the application
                        » Make sure you are connecting router from the modem LAN to Router WAN port
                           then follow the steps mentioned on the article below
Hello enlarson
  • October 17, 2023
The advertizing for this set up should be penalized in some way for false advertising...”easy” is absolute BS.  There’s no reset button as the troubleshooter tells you to use.  Just spinning wheel of death on the app.  Arris should be ashamed of themselves.
I am having the same problem as above and am unable to overcome it. I have followed the instructions provided multiple times, on two different phones, and have the same problem. My phone and the app says it is successfully connected to the SurfboardOnboarding network, the router is alternating green and white, and the app just spins until it says there is a wi-fi communication failure error code 0006-1205. Thank you for any help anyone can provide.
  • June 8, 2024
I think I figured it out, if you haven’t yet.
The problem might be that your phone keeps connecting to your original network. When it’s available, try switching to the “onboarding” app.
Also, not sure what modem you’re using, but we’re using the Xfinity xFI Gateway (most current model). What the app *doesn’t* tell you is that your modem has to be in BRIDGE MODE!
Setting it up with everything mentioned above worked like a charm, and fairly fast!
HOWEVER… we *did* run into some rather major issues when setting up the satellite router. This took many, many tries. But, eventually, we got it. I called tech support over this, and it took us well over an hour to get it all copacetic. It’s working just fine now, though!
Like I said, I’m sure you figured this out already (or returned the thing). But, maybe this will help someone else out who has the same issue.
  • July 7, 2024
I am using a TMobile internet router. I performed a hard reset on it and have done resets on the Mesh router twice.  At one point it did an update on the mesh router. The app connects to the Surfboard-Onboarding fine. However, when it tries to get internet I continually get error 0006-1205. This is even after a hard reset on the modem and resets on the mesh router. None of the troubleshooting appears to help.
