How to log into router
  • June 6, 2023
  • 356 views
Hello moose4465,
We understand you would like to login on the Router , could you let us know the model number of the Max Mesh?
Are you trying to login on the Surfboard Central App ?
Follow the below mentioned link to setup Surfboard Central App :
Let us know if this helps.
Hello moose4465,
  • June 22, 2023
If you have a SURFboard Mesh router, there’s no web interface. Use the SURFboard Central app to access the settings.
