How to log into router
  • 6 June 2023
  • 126 views
Best answer by SURFboard Moderator 22 June 2023, 19:14
Hello moose4465,
We understand you would like to login on the Router , could you let us know the model number of the Max Mesh?
Are you trying to login on the Surfboard Central App ?
Follow the below mentioned link to setup Surfboard Central App :
Let us know if this helps.
Userlevel 3
Badge +23
If you have a SURFboard Mesh router, there’s no web interface. Use the SURFboard Central app to access the settings.
