Hello. I'm trying to set up the Surfboard W31 router. I'm using Surfboard Central from the Google Play Market (the latest version) for the setup, and my mobile phone is a Samsung S22+. I don't have any problems with the initial setup. However, the Surfboard Central app simply doesn't save the settings, and after exiting, it suggests going through the initial setup again (which would require resetting the router settings). What should I do?
Yes, i tried to reboot the phone :) - no luck.
