2.4GHz Network and a 5GHz Network W130/W30
  • September 11, 2023
  • 144 views
Does the MaxPro also support two separate wireless networks. Most of my devices do just fine with smart connect, but I have one door lock that will only work on 2.4 and will not work with smart connect.
Thanks
Hello beastman
                            For W130/W30 there is no such option available so you wont be able to separate or create 2.4 and 5G network. This mesh system will pick allow the network according to the device compatibility.
Hello beastman
