Android v14 will not connect via Bluetooth to W130
  • August 30, 2024
  • 151 views
New W133 Router will not connect via Bluetooth. Have re-installed Surfboard Central several times, went through complete setup process per Community Group forum recommendations, Android devise sees the Max Pro router in Bluetooth settings and pairing mode, Max Pro continues with blue blinking light- will not connect. Tried Factory reset to no avail. Also using Arris Surfboard S33 Modem.
Same thing is happening for me.
  • August 31, 2024
Spent 1.5 w Arris tech went through many iterations of connection attempts. All failed. so returning unit.
