How can I access the SURFboard MAX “ PC based admin login” instead of SOFTboard Central ?
  • September 23, 2023
  • 270 views
I want to be able to log in after a “factory reset”.
Hello AshbyB
                       Using Surfboard central application on the PC is not possible and after resetting you can try uninstalling app and re install then try logging in if still you are unable to login you can try using different email address for login the SBC app.
Hello AshbyB
  • October 8, 2023
Thanks.
