INCORRECT PRODUCT IN THE W133 BOX
  • July 14, 2023
  • 69 views
I PURCHASED A SET OF SURFBOARD W31 ROUTERS A FEW YEARS AGO.
PERFORMANCE IS GREAT
I FELT IT WAS TIME TO UPGRADE SO THROUGH AMAZON I ORDERED W133 ROUTERS
THE ACTUAL UNITS THAT CAME IN THE BOX SAY W31 ON THE UNITS.
IS THAT A MISTAKE IN BOXING?
Hello @blackhart762
The mAX W161 is the upgrade model for W133 Mesh system.  The mAX W161 includes 2.5 Gb WAN Ethernet Port for multi-gig Internet speed and Wi-Fi 6e for 6 GHz band support.  You would need to replace your W31s with the W161 system.  The W161 cannot be added to the existing SURFboard Mesh network.
Here are additional information https://www.surfboard.com/products/max-mesh-wi-fi-systems/w161/
Hi blackhart762,
The W31 is a single router and W133 is a dual router . Also W133 is not the upgraded version of W31 , the actual unit that you had purchased is W31 (Dual Routers)  which is also known as W133 .
Please check the link of W133 : https://www.surfboard.com/products/max-mesh-wi-fi-systems/w133/.
Let us know if this helps .
  • July 17, 2023
So there is no reason to upgrade to a newer system since my system is the same?
Is there an upgrade to what I have?
Forum|alt.badge.img+17
Hello @blackhart762
