IS my W31 Compatible with W21
  • May 31, 2022
  • 183 views
Hello Community, i do have an dual pack W31 installed on my house, i wanted to add another mesh to expand the coverage but find out that the W31 goes a bit out of my budget, i saw the W21 in a lower price, will be this one compatible with my setup?
The W21 cannot be installed in the network with W30 or W31 mAX.  You can mix only W30 or W31 between each other, and also have an maximum of 3 devices *(Main router + 2 Satellites)
Forum|alt.badge.img+17
