When trying to add a mAX Pro W31 satellite I get the the registration part and the app kick me out and closes. I check the app for updates but the app is up to date. Any body know why I can’t add the satellite or why it kicks me out?
mAX Pro W31 trying to add 2nd satellite
Since you tried all the steps to connect the satellite, I suggest you swap the routers ( satellite as the main router and main router as a satellite).
After swapping, uninstall the application reinstall it again, and set it up.
