I just got a w130 surfboard max plus system. I’ve been around computers over 25 years so I’m not a complete noob.
I have to say the app leaves a lot to be desired.
I have a Netgear CM1000v2 cable modem (not WiFi). The app at one point tells me to connect the Ethernet cable to the WAN port on the w130. I may be assuming a lot but the only Ethernet it could be is the output from the Netgear modem. That is the same cable that connected the modem to the router I’m trying to replace. Then on the next page it asks for the WiFi login. It will not under any circumstances let me use the wired connection even though it just instructed me to do it.
Any suggestions? Thanks.
