need additional mesh router satellite with w133
  • March 8, 2025
  • 145 views
I recently created my home network with the W133 mesh system. I would like to add one more mesh router to the system. Can I purchase a single W133 router or do I have to buy the system with 2? Is there another mesh router that would be compatible with my W133 system?
Certainly! You can purchase a separate mAX Plus W30 or mAX Pro W31 to add to your existing W133 system.
With your current W133 mesh setup, you can add one mAX Plus W30 or mAX Pro W31 as a satellite to enhance your network.
The total system consisting of three routers, allowing you to have one main router and two satellites in the W133 series. The same applies to both the mAX Plus W30 and mAX W21 models
  • March 23, 2025
I ordered what was supposed to be a single W30 satellite to add to my set up but what came was a W130 mesh system with 2 routers. Can I use one of the W130 routers as a satellite with my W133 system?
Sure ​@Sadams, You can integrate a W30 unit with your existing W133 mesh system.
