Power supply stop working.
  • April 26, 2023
  • 56 views
I bought SURFboard MAX w133 in 04/22 in EUA so I configured the modem today (04/25) at my home in Brazil.
One of these power supplies stopped working a few hours later on my first setup.
I tested the modems and both are working.
What do I need to do to get support to replace?
TechRep
Cable Modem Commandos
Forum|alt.badge.img+9
  • Cable Modem Commandos
  • April 26, 2023
Hi Marco, unfortunately they do not ship to countries outside of US. If you have a physical address in USA where they can send the power cord and then from that physical address having someone redirecting the power cord to you will be the best option
these are the specifications in case you can search for one cable online or in your local area
Power Required Amperage PIN Type Type
12vDC 3.0A POS(+) Wall Wart
  • April 26, 2023
What is the plug type of the power supply?
This is a P4 Plug?
