Surfboard app can't connect to Max router
  • July 21, 2022
  • 229 views
My mesh network is working, and I’m connected to the internet, but the surfboard app cannot connect to the router.
Are you on iOS? if so, make sure icloud relay and private mac/ip address are disabled.
  • 2287 replies
  • July 23, 2022
