surfboard w30 where can I get the configuration app
  • June 8, 2023
  • 267 views
Please provide me a link to download a app that configures the board w30
I have android system
If you have for another system please too
Really appreciated .please send links
I found on play store a surfboard central but there's no model board w30 that's why I need to know where download or what donwload from Playstore
Thanks
My number 9994559266
Hi felipe,
Kindly choose the model number for W30 is Max Plus 7800.
Hello felipe,
As you are unable to access the model board of W30 .
If you are using the cable modem to connect to the W30 , Follow the link below :
http://arris.force.com/consumers/articles/General_FAQs/mAX-W30-W31-Cable-Modem-Internet-Setup
If you are using the Wi-Fi cable modem to connect to the W30, Follow the link below
http://arris.force.com/consumers/articles/General_FAQs/mAX-W30-W31-Wi-Fi-Cable-Modem-Internet-Setup
Note: On the select your device below : choose Surfboard Max  not the Surfboard Modem the ISP cable connected without Wi-Fi
  • June 11, 2023
Thanks in advance i work repairing fixing computers on mexico. someone has in his house the surfboardtable and want that i configure ( it's my job )
Here is What i do is this i open the app and i click on app on
Get started
Continue
I chose surfboard max
And this all the models that the app show me ( Android app )
Models on pictures
And what i see on The surfable label says w30
So no option for
I add pictures
I wonder if I have to pick any of the models that app shows even it doesn't say w30
  • June 11, 2023
This is the label on device it says w30 but theres no w30 model on app
Thanks friends
Blessings
  • June 19, 2023
Wich model i have tochoose if there's no model w30 option in the surfboard center application Android??
Thanks
Hi felipe,
