View devices on guest network. Surfboard W130
  • March 8, 2025
  • 80 views
Title sort of explains it. I'm wondering if there's a way to see the devices connected to the guest network. I'm using the Surfboard W130. Everything else has been somewhat easy to manage, but I'm trying to ensure my smart lightbulbs are using the guest network as opposed to the main one.
The W130 is a dual pack consisting of two mAX Plus W30 units. When you are connected to your main network, you can easily recognize the devices under the 'My Devices' section, which shows the connected devices. However, when connected to the guest network, the devices will not appear under the connected list. Please note that the guest network is different from the main network, as it operates as an additional network.
